[petsc-dev] windows fixes.
Fri Jun 28 12:01:54 CDT 2013
Appears to work now.
thanks!
Satish
On Fri, 28 Jun 2013, Jed Brown wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
> >   Clumsy code it is :-)
> Fixed in 'next'.
> commit 96c122f7ff11b2781a634ef7c59f013fab739c6b (jed/config-cleanup)
> Author: Jed Brown <jedbrown at mcs.anl.gov>
> Date:   Fri Jun 28 10:39:37 2013 -0500
>     config: python-2.4 does not support decorators
>     This amends 2a571ffb5945aee7 to avoid decorators.
> diff --git a/config/BuildSystem/config/setCompilers.py b/config/BuildSystem/config/setCompilers.py
> index a7c1507..0b3325c 100644
> --- a/config/BuildSystem/config/setCompilers.py
> +++ b/config/BuildSystem/config/setCompilers.py
> @@ -124,8 +124,6 @@ class Configure(config.base.Configure):
>      return 0
>    isNAG = staticmethod(isNAG)
> -  @staticmethod
> -  @config.memoize
>    def isGNU(compiler):
>      '''Returns true if the compiler is a GNU compiler'''
>      try:
> @@ -148,6 +146,7 @@ class Configure(config.base.Configure):
>      except RuntimeError:
>        pass
>      return 0
> +  isGNU = staticmethod(config.memoize(isGNU))
>    def isClang(compiler):
>      '''Returns true if the compiler is a Clang/LLVM compiler'''
