[petsc-dev] [petsc-maint] Updating PETSc to support Elemental 0.80
Jack Poulson jack.poulson at gmail.com
Sun Jun 16 20:08:34 CDT 2013
On Sun, Jun 16, 2013 at 4:37 PM, Jack Poulson <jack.poulson at gmail.com>wrote:
> On Sun, Jun 16, 2013 at 4:09 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Sun, 16 Jun 2013, Jack Poulson wrote:
>> > I have been experimenting with having Clique checkout both pkg-metis and
>> > pkg-parmetis as part of its build system and it seems that a few things
>> > need to be added to the parmetis CMakeLists.txt for it to function
>> > correctly (please correct me if I am missing something!).
>> > The two main problems are the inclusion of gklib_tls.h and gklib_defs.h,
>> > where the former is generated by the metis build system, usually in
>> > metis/include in the installation directory, and the latter is is in
>> > metis/libmetis/ in the source directory. While setting METIS_PATH to the
>> > metis installation directory would pick up gklib_tls.h since
>> > ${METIS_PATH}/include is added to the include directories of the
>> parmetis
>> > CMakeLists.txt, I do not see any corresponding include_directories
>> > statement for the libmetis directory containing gklib_defs.h.
>> Its also installed in CMAKE_INSTALL_PREFIX/include?
>> https://bitbucket.org/petsc/pkg-metis/commits/7352fdb4f3027f2330d69896c938fc4996f66461
> Apparently so. but I am trying to build metis and parmetis as part of the
> build (my CMakeLists.txt checks out the pkg-metis and pkg-parmetis
> repositories). I would prefer to be able to do things this way instead of
> requiring metis to have been installed previously. I should have been more
> clear with my previous language: when I said 'installation' directory, I
> should have said 'build' directory.
Additionally, pkg-metis does not seem to be iinstalling enough header files
for parmetis to be successfully built. In particular, it is not installing
the headers from the GKlib folder:
poulson at poulson-ThinkPad-E520:~/Source/External/pkg-metis/build$ make
install
[100%] Built target metis
Install the project...
-- Install configuration: ""
-- Up-to-date: /home/poulson/Source/Install/include/metis.h
-- Up-to-date: /home/poulson/Source/Install/include/gklib_tls.h
-- Up-to-date: /home/poulson/Source/Install/lib/libmetis.a
-- Up-to-date: /home/poulson/Source/Install/include/gklib_defs.h
-- Up-to-date: /home/poulson/Source/Install/include/gklib_rename.h
What is the recommended means of coupling pkg-metis and pkg-parmetis?
Jack
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130616/84523ce9/attachment.html>
