[petsc-dev] [petsc-maint] Updating PETSc to support Elemental 0.80
Jack Poulson jack.poulson at gmail.com
Sun Jun 16 18:37:14 CDT 2013
On Sun, Jun 16, 2013 at 4:09 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Sun, 16 Jun 2013, Jack Poulson wrote:
> > I have been experimenting with having Clique checkout both pkg-metis and
> > pkg-parmetis as part of its build system and it seems that a few things
> > need to be added to the parmetis CMakeLists.txt for it to function
> > correctly (please correct me if I am missing something!).
> > The two main problems are the inclusion of gklib_tls.h and gklib_defs.h,
> > where the former is generated by the metis build system, usually in
> > metis/include in the installation directory, and the latter is is in
> > metis/libmetis/ in the source directory. While setting METIS_PATH to the
> > metis installation directory would pick up gklib_tls.h since
> > ${METIS_PATH}/include is added to the include directories of the parmetis
> > CMakeLists.txt, I do not see any corresponding include_directories
> > statement for the libmetis directory containing gklib_defs.h.
> Its also installed in CMAKE_INSTALL_PREFIX/include?
> https://bitbucket.org/petsc/pkg-metis/commits/7352fdb4f3027f2330d69896c938fc4996f66461
Apparently so. but I am trying to build metis and parmetis as part of the
build (my CMakeLists.txt checks out the pkg-metis and pkg-parmetis
repositories). I would prefer to be able to do things this way instead of
requiring metis to have been installed previously. I should have been more
clear with my previous language: when I said 'installation' directory, I
should have said 'build' directory.
Jack
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130616/9b53af00/attachment.html>
