[petsc-dev] reproducibility
Sun Jun 9 18:38:32 CDT 2013
On Mon, Jun 10, 2013 at 12:32 AM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hey,
> >         With -citations, or in addition to it, we should have some flag
>>     that causes the print out of the unique version information for each
>>     package used in a computation. Since computations are often done
>>     "between" version releases or with "randomly" patched releases how
>>     can we capture that information?
>> I think getting version information from other packages is pretty
>> worthless (how many times has SuperLU
>> had a shadow release). However, for all the packages that we control, we
>> can get the SHA1 very simply.
>> So a list of SHA1s for all packages would be meaningful.
> Yeah, SHA1 is fine. One problem, however, is the reverse-lookup, i.e.
> trying to 'find' the correct packages with given SHA1s in order to e.g.
> reproduce some results. If we provide all external packages out of our own
> download repositories, we can keep track of the SHA1s in use. With external
> download URLs, however, such a trace-back might be fairly hard or even
> impossible. Thus, we might want to consider some date information in
> addition to the SHA1 just to have a hint in case a SHA1 cannot be matched.
I am saying its not possible without managing the repo.
  Matt
> Best regards,
> Karli
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130610/9f7b7fe1/attachment.html>
