[petsc-dev] make -j not supported? Why???
Karl Rupp rupp at mcs.anl.gov
Mon Feb 25 19:19:55 CST 2013
Hi Tim,
have you looked at make.log? It records the compiler commands there.
Best regards,
Karli
On 02/25/2013 07:00 PM, Tim Tautges wrote:
> Ok, I may be going off experience with 3.1 or getting my env variables
> messed up.
> Better error message for the make -j thing is definitely a plus.
> The next problem: I'm trying to see the actual compile line used to
> build my source file, because an include file isn't being found.  I'm
> sure this is something I'm missing, but it would be easier to diagnose
> if I could see the compile command.  Any clues?
> Thanks.
> - tim
> On 02/25/2013 04:49 PM, Barry Smith wrote:
>> On Feb 25, 2013, at 2:30 PM, Tim Tautges <tautges at mcs.anl.gov> wrote:
>>> but why its need to not support otherwise-standard make options?
>>> Similarly, PETSC_MAKE_STOP_ON_ERROR instead of
>>> make -k?
>> Hmm, with the cmake based build -k seems to work fine, it keeps on
>> going compiling everything it can. Without the -k
>> it stops when the first compile fails. So it is supporting the
>> "otherwise-standard make options".
>> Yes, the legacy build which is only a fallback for when cmake fails,
>> is funky. Are you using it? If so, let us know
>> why and we'll try to improve the cmake version so that you don't need
>> the legacy; even I don't use it any more.
>> Barry
>>> - tim
>>> "You will keep in perfect peace him whose mind
>>> is steadfast, because he trusts in you."               Isaiah 26:3
>>> Tim Tautges            Argonne National Laboratory
>>> (tautges at mcs.anl.gov)      (telecommuting from UW-Madison) phone
>>> (gvoice): (608) 354-1459      1500 Engineering Dr. fax: (608)
>>> 263-4499      Madison, WI 53706
