[petsc-dev] ugliness due to missing lapack routines
Karl Rupp rupp at mcs.anl.gov
Sat Feb 9 10:22:35 CST 2013
I'm super-late in jumping in (again) into the discussion. Before we can
even think about doing anything C-AST-related, we need to reduce the CPP
usage to a much smaller amount. I'll try to come up with a
categorization of CPP usage in PETSc during next week.
Some of the CPP macros are fairly simple to be integrated into a C-AST.
Conditional objects including operations on them are a lot harder, e.g.
void my_func()
   PetscInt   ierr;
#if defined(PETSC_HAVE_SOMETHING)
   PetscInt   headache;
#endif
   PetscFunctionBegin;
   some_func(headache);
#else
   other_func();
#endif
I think the most frequent use is due to the TX-GPU-Package, but there
are a couple of other cases where the presence of some optional package
leads to such code.
Best regards,
Karli
On 02/08/2013 12:20 AM, Jed Brown wrote:
> On Fri, Feb 8, 2013 at 12:10 AM, Barry Smith <bsmith at mcs.anl.gov
> <mailto:bsmith at mcs.anl.gov>> wrote:
>      > How would they specify what they want to use? Hopefully using the
>     options database.
>        Of course.
>      > Inlining could then be thought of as an extreme case of
>     profile-guided optimization, in the sense that you run an
>     instrumented instance of the code to determine which decisions have
>     been made, then recompile (mostly just fusing the right things) and
>        Yup.
> Did we just converge?
> I was just getting in the groove. ;-)
