[petsc-dev] Huh?
Wed Feb 6 07:27:04 CST 2013
  Disappeared with a fresh install of MPICH.
   Barry
On Feb 5, 2013, at 10:34 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Valgrind-clean here as of https://bitbucket.org/petsc/petsc-dev/commits/4e55cead1b3e383fa57e9479d00c8f2dd75b4874. I haven't tested more recently, but don't see anything that looks obviously bad. Which mpich version do you have?
> On Tue, Feb 5, 2013 at 10:20 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Anybody mucking things up?
>    Barry
> error: No such file or directory - old dSYM file cannot be overwritten:         old: '/Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpl.1.dylib.dSYM/Contents/Resources/DWARF/libmpl.1.dylib'
>         new:'/Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpl.1.dylib.dSYM/Contents/Resources/DWARF/libmpl.1.dylib.x86_64'.
> ==10247== Invalid read of size 8
> ==10248== Invalid read of size 8
> ==10247==    at 0x111D08B: MPIDI_CH3U_Recvq_FDU_or_AEP (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpich.8.dylib)
> ==10247==    by 0x1127B9E: MPID_Irecv (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpich.8.dylib)
> ==10247==    by 0x10ACB94: MPI_Irecv (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpmpich.8.dylib)
> ==10248==    at 0x111D08B: MPIDI_CH3U_Recvq_FDU_or_AEP (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpich.8.dylib)
> ==10248==    by 0x1127B9E: MPID_Irecv (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpich.8.dylib)
> ==10248==    by 0x10ACB94: MPI_Irecv (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpmpich.8.dylib)
> ==10248==    by 0x11D35E: VecScatterCreate_PtoS (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10247==    by 0x11D35E: VecScatterCreate_PtoS (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10247==    by 0x106AE8: VecScatterCreate (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10247==    by 0x3C7449: DMSetUp_DA_2D (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10248==    by 0x106AE8: VecScatterCreate (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10248==    by 0x3C7449: DMSetUp_DA_2D (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10248==    by 0x3F4122: DMSetUp_DA (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10247==    by 0x3F4122: DMSetUp_DA (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10247==    by 0x45DC09: DMSetUp (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10248==    by 0x45DC09: DMSetUp (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10248==    by 0x3C8556: DMDACreate2d (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10247==    by 0x3C8556: DMDACreate2d (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10247==    by 0x10000150A: main (in ./ex19)
> ==10247==  Address 0x10002af60 is 16 bytes after a block of size 32 alloc'd
> ==10248==    by 0x10000150A: main (in ./ex19)
> ==10248==  Address 0x10002af60 is 16 bytes after a block of size 32 alloc'd
> ==10247==    at 0xC713: malloc (vg_replace_malloc.c:274)
> ==10247==    by 0x112A916: MPID_VCRT_Create (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpich.8.dylib)
> ==10248==    at 0xC713: malloc (vg_replace_malloc.c:274)
> ==10248==    by 0x112A916: MPID_VCRT_Create (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpich.8.dylib)
> ==10247==    by 0x112770C: MPID_Init (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpich.8.dylib)
> ==10247==    by 0x1177703: MPIR_Init_thread (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpich.8.dylib)
> ==10247==    by 0x10ABF31: MPI_Init_thread (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpmpich.8.dylib)
> ==10248==    by 0x112770C: MPID_Init (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpich.8.dylib)
> ==10248==    by 0x1177703: MPIR_Init_thread (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libmpich.8.dylib)
> ==10247==    by 0x41B38: PetscInitialize (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10247==    by 0x100001448: main (in ./ex19)
> ==10247==
> ==10248==    by 0x10ABF31: MPI_Init_thread (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpmpich.8.dylib)
> ==10248==    by 0x41B38: PetscInitialize (in /Users/barrysmith/Src/petsc-dev/arch-opt/lib/libpetsc.dylib)
> ==10248==    by 0x100001448: main (in ./ex19)
> ==10248==
