[petsc-dev] Python version
Mon Feb 4 20:20:51 CST 2013
On Mon, Feb 4, 2013 at 8:14 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> I was actually thinking of the Python interface for PETSc rather than the
> build system. For the build system we should support any 2.x version. And,
> even worse, I expect that at some point both 2.x and 3.x need to be
> supported concurrently...
I don't think we'll support 3.x until dropping support for 2.5 (because 2.6
is the first version that has compatible exception-handling syntax). It's
pretty important to have a single source.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130204/f5388662/attachment.html>
