[petsc-dev] Python version
Karl Rupp rupp at mcs.anl.gov
Mon Feb 4 20:14:39 CST 2013
> The article has massive selection bias: all people surveyed are actively
> using Python in their work. Many PETSc users don't write Python at all,
> PETSc is just using it for the build. If latter population was as
> up-to-date as these astro folks, we'd be able to drop compatibility for
> 10-year old versions of Python and upgrade a lot of cruddy code.
I was actually thinking of the Python interface for PETSc rather than
the build system. For the build system we should support any 2.x
version. And, even worse, I expect that at some point both 2.x and 3.x
need to be supported concurrently...
Best regards,
Karli
