[petsc-dev] Pushing non-working code
Sat Feb 2 16:38:40 CST 2013
On Sat, Feb 2, 2013 at 5:20 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Sat, Feb 2, 2013 at 4:14 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> I think non-working is a misnomer here. These do not break the build.
> They issue warnings and the code can't possibly execute correctly. Just
> don't push it (or push it somewhere else) until it's been cleaned up to the
> point where it's not wasting our time to review.
I would love it if people never pushed code with any bugs. This is
possible, just not efficient. All changes to
workflow should be evaluated on this basis. For this particular change,
  1) It does not break the build
  2) Its a new feature, so does not break tests except the ones its
supposed to
I do think warnings are annoying and people should endeavor to push code
with no
warnings, but making this a requirement takes away flexibility while
providing nothing
I can see except lack of Jed Annoyance. The claim that you are code
reviewing this
push is false on its face.
I think this play into a larger issue. Does the increased process burden
you are recommending
actually bring increased productivity. That the answer is yes is not at all
clear. It is easy to make
the mistake that because something sounds good and "right" that you should
do it. This dooms
most CS projects.
   Matt
> Related: I would like to start tweaking our workflow to make petsc-dev
> more consistently stable, so that more applications can work with it
> instead of needing to wait for a release. Having people pushing code that
> doesn't work, isn't tested, and obviously wouldn't pass review is not good
> for stability.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130202/3aa6bc3b/attachment.html>
