[petsc-dev] Adding Seq Dense MAGMA Mat
Harshad Sahasrabudhe hsahasra at purdue.edu
Tue Aug 27 23:12:29 CDT 2013
   > I am fine with adding just the LU factorization in dense.c for now.
 > Right, do the simple thing now.  You'll be able to reuse the code even
 > if you later decide that you need the more complicated solution.
Okay, I'll start working on that then.
Harshad
