[petsc-dev] Adding Seq Dense MAGMA Mat
Tue Aug 27 23:09:57 CDT 2013
Harshad Sahasrabudhe <hsahasra at purdue.edu> writes:
> I am fine with adding just the LU factorization in dense.c for now.
Right, do the simple thing now.  You'll be able to reuse the code even
if you later decide that you need the more complicated solution.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130827/4b2dd9a3/attachment.sig>
