[petsc-dev] git bitbucket trouble
Sat Aug 24 09:43:40 CDT 2013
  Who writes the error messages for these guys, they are worse than PETScs
src refspec barry/hyprewithprinterror does not match any.
On Aug 24, 2013, at 9:34 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>  WTF?
>> ~/Src/petsc  barry/hyprewithprinterrors $ git commit -a
> This branch has plural errors (trailing 's').
>> [barry/hyprewithprinterrors 69ccb71] debug version of downloaded hypre compiled with --with-print-errors to help debugging
>> 1 file changed, 4 insertions(+)
>> ~/Src/petsc  barry/hyprewithprinterrors $ git push
>> fatal: The current branch barry/hyprewithprinterrors has no upstream branch.
>> To push the current branch and set the remote as upstream, use
>>    git push --set-upstream origin barry/hyprewithprinterrors
>> ~/Src/petsc  barry/hyprewithprinterrors $ git push --set-upstream origin barry/hyprewithprinterror
> You're trying to push a singular error (no trailing 's' in the branch
> name).  Tab complete should work here.
