[petsc-dev] git bitbucket trouble
Sat Aug 24 09:34:11 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>   WTF?
> ~/Src/petsc  barry/hyprewithprinterrors $ git commit -a
This branch has plural errors (trailing 's').
> [barry/hyprewithprinterrors 69ccb71] debug version of downloaded hypre compiled with --with-print-errors to help debugging
>  1 file changed, 4 insertions(+)
> ~/Src/petsc  barry/hyprewithprinterrors $ git push
> fatal: The current branch barry/hyprewithprinterrors has no upstream branch.
> To push the current branch and set the remote as upstream, use
>     git push --set-upstream origin barry/hyprewithprinterrors
> ~/Src/petsc  barry/hyprewithprinterrors $ git push --set-upstream origin barry/hyprewithprinterror
You're trying to push a singular error (no trailing 's' in the branch
name).  Tab complete should work here.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130824/16ad6556/attachment.sig>
