[petsc-dev] Error while building MAGMA from PETSc
Thu Aug 15 19:46:00 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
> This is even worse. Just let Barry pollute our code with bad solutions
> that we will eventually have to fix up by doing it right.
Whatever the solution, we cannot allow -DHAVE_CUBLAS into a CFLAGS that
a user would obtain from PETSc makefiles.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130815/956e523f/attachment.sig>
