[petsc-dev] Error while building MAGMA from PETSc
Thu Aug 15 14:33:33 CDT 2013
... and send the changes you have made. One way to do that is to 'git add
config/PETSc/packages/magma.py' and send the output if 'git diff master'.
On Aug 15, 2013 2:28 PM, "Matthew Knepley" <knepley at gmail.com> wrote:
> On Thu, Aug 15, 2013 at 1:56 PM, Harshad Sahasrabudhe <hsahasra at purdue.edu
> > wrote:
>> Hi,
>> Now MAGMA compiles correctly and libmagma.a is generated, however PETSc
>> says
>>       Downloaded magma could not be used. Please check install in
>> /home/harshad/workspace/petsc-hg/arch-linux2-c-debug
>> I am copying the generated library and include files to the install
>> directory using
>>         includeDir = os.path.join(self.installDir, self.includedir)
>>         output,err,ret = PETSc.package.NewPackage.executeShellCommand('cd
>> '+self.packageDir+' && mv -f lib/*.* '+libDir+'/. && cp -f include/*.*
>> '+includeDir+'/.', timeout=2500, log = self.framework.log)
>> I need help in resolving this error.
> Always send configure.log.
>    Matt
>> Thanks,
>> Harshad
>> ----- Original Message -----
>> From: "Matthew Knepley" <knepley at gmail.com>
>> To: "Harshad Sahasrabudhe" <hsahasra at purdue.edu>
>> Cc: "For users of the development version of PETSc" <
>> petsc-dev at mcs.anl.gov>
>> Sent: Wednesday, August 14, 2013 6:27:04 PM
>> Subject: Re: [petsc-dev] Error while building MAGMA from PETSc
>> On Wed, Aug 14, 2013 at 5:23 PM, Harshad Sahasrabudhe <
>> hsahasra at purdue.edu > wrote:
>> Hi,
>> I'm trying the write the package compiler for MAGMA using PETSc build
>> system. I'm getting the following error while building MAGMA. With the
>> error, I'm also getting a couple hundred warnings:
>> sormqr_gpu_2stage.cpp: In function ‘magma_int_t
>> magma_sormqr_gpu_2stages(char, char, magma_int_t, magma_int_t, magma_int_t,
>> float*, magma_int_t, float*, magma_int_t, float*, magma_int_t,
>> magma_int_t*)’:
>> sormqr_gpu_2stage.cpp:98: warning: unused variable ‘c_one’
>> sormqr_gpu_2stage.cpp:107: warning: unused variable ‘lwkopt’
>> strsm_m.cpp: In function ‘magma_int_t magma_strsm_m(magma_int_t, char,
>> char, char, char, magma_int_t, magma_int_t, float, float*, magma_int_t,
>> float*, magma_int_t)’:
>> strsm_m.cpp:181: warning: unused variable ‘jj’
>> strsm_m.cpp:181: warning: unused variable ‘jjb’
>> sgeev.cpp: In function ‘magma_int_t magma_sgeev(char, char, magma_int_t,
>> float*, magma_int_t, float*, float*, float*, magma_int_t, float*,
>> magma_int_t, float*, magma_int_t, magma_int_t*)’:
>> sgeev.cpp:126: warning: unused variable ‘c_n1’
>> nvcc fatal : redefinition of argument 'gpu-architecture'
>> What is the easiest way to debug this kind of an error?
>> 1) Make the MAGMA build system print out the full compile line
>> 2) Make the MAGMA people clean up their sloppy code, which would
>> eliminate the warnings
>> Matt
>> Thanks,
>> Harshad
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130815/56be20de/attachment.html>
