[petsc-dev] Error while building MAGMA from PETSc
Thu Aug 15 14:27:52 CDT 2013
On Thu, Aug 15, 2013 at 1:56 PM, Harshad Sahasrabudhe
<hsahasra at purdue.edu>wrote:
> Hi,
> Now MAGMA compiles correctly and libmagma.a is generated, however PETSc
> says
>       Downloaded magma could not be used. Please check install in
> /home/harshad/workspace/petsc-hg/arch-linux2-c-debug
> I am copying the generated library and include files to the install
> directory using
>         includeDir = os.path.join(self.installDir, self.includedir)
>         output,err,ret = PETSc.package.NewPackage.executeShellCommand('cd
> '+self.packageDir+' && mv -f lib/*.* '+libDir+'/. && cp -f include/*.*
> '+includeDir+'/.', timeout=2500, log = self.framework.log)
> I need help in resolving this error.
Always send configure.log.
   Matt
> Thanks,
> Harshad
> From: "Matthew Knepley" <knepley at gmail.com>
> To: "Harshad Sahasrabudhe" <hsahasra at purdue.edu>
> Cc: "For users of the development version of PETSc" <petsc-dev at mcs.anl.gov
> Sent: Wednesday, August 14, 2013 6:27:04 PM
> Subject: Re: [petsc-dev] Error while building MAGMA from PETSc
> On Wed, Aug 14, 2013 at 5:23 PM, Harshad Sahasrabudhe <
> hsahasra at purdue.edu > wrote:
> Hi,
> I'm trying the write the package compiler for MAGMA using PETSc build
> system. I'm getting the following error while building MAGMA. With the
> error, I'm also getting a couple hundred warnings:
> sormqr_gpu_2stage.cpp: In function ‘magma_int_t
> magma_sormqr_gpu_2stages(char, char, magma_int_t, magma_int_t, magma_int_t,
> float*, magma_int_t, float*, magma_int_t, float*, magma_int_t,
> magma_int_t*)’:
> sormqr_gpu_2stage.cpp:98: warning: unused variable ‘c_one’
> sormqr_gpu_2stage.cpp:107: warning: unused variable ‘lwkopt’
> strsm_m.cpp: In function ‘magma_int_t magma_strsm_m(magma_int_t, char,
> char, char, char, magma_int_t, magma_int_t, float, float*, magma_int_t,
> float*, magma_int_t)’:
> strsm_m.cpp:181: warning: unused variable ‘jj’
> strsm_m.cpp:181: warning: unused variable ‘jjb’
> sgeev.cpp: In function ‘magma_int_t magma_sgeev(char, char, magma_int_t,
> float*, magma_int_t, float*, float*, float*, magma_int_t, float*,
> magma_int_t, float*, magma_int_t, magma_int_t*)’:
> sgeev.cpp:126: warning: unused variable ‘c_n1’
> nvcc fatal : redefinition of argument 'gpu-architecture'
> What is the easiest way to debug this kind of an error?
> 1) Make the MAGMA build system print out the full compile line
> 2) Make the MAGMA people clean up their sloppy code, which would eliminate
> the warnings
> Matt
> Thanks,
> Harshad
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130815/5a43b78d/attachment.html>
