[petsc-dev] examples/benchmarks for weak and strong scaling exercise
Chris Kees cekees at gmail.com
Fri Apr 12 09:18:49 CDT 2013
I updated the results for the Bratu problem on our SGI. It has 8 cores
per node (two 4-core processors per node), and I ran from 1 to 256
cores.  The log_summary output is attached for both studies. Question:
is there anything about the memory usage of that problem that doesn't
scale? The memory usage looks steady at < 1GB per core based on
log_summary.  I ask because last night I tried to do one more level of
refinement for weak scaling on 1024 cores and it crashed. I ran the
same job on 512 cores this morning, and it ran fine so I'm hoping the
issue was a temporary system problem.
Notes:
There is a shift in the strong scaling curve as it fills up the first
node (i.e. from 1 to 16 cores), then it looks perfect.  The shift
seems reasonable due to the sharing of the cache by 4 cores.
The weak scaling shows slight growth in the wall clock from 6.3
seconds to 17 seconds.  I'm going to run that again with a larger
coarse grid in order to increase the runtime to several minutes.
Graphs: https://proteus.usace.army.mil/home/pub/17/
On Thu, Apr 11, 2013 at 12:46 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Chris Kees <cekees at gmail.com> writes:
>> Thanks a lot. I did a little example with the Bratu problem and posted it here:
>> I used boomeramg instead of geometric multigrid because I was getting
>> an error with the options above:
>> %mpiexec -np 4 ./ex5 -mx 129 -my 129 -Nx 2 -Ny 2 -pc_type mg -pc_mg_levels 2
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Argument out of range!
>> [0]PETSC ERROR: New nonzero at (66,1) caused a malloc!
>> [0]PETSC ERROR:
> That test hard-codes evil things (presumably for testing purposes,
> though maybe the functionality has been subsumed).  Please use
> src/snes/examples/tutorials/ex5.c instead.
>  mpiexec -n 4 ./ex5 -da_grid_x 65 -da_grid_y 65 -pc_type mg -log_summary -da_refine 1
> Increase '-da_refine 1' to get higher resolution.  (This will increase
> the number of MG levels used by PCMG.)
> Switch '-da_refine 1' to '-snes_grid_sequence 1' if you want FMG, but
> note that it's trickier to profile because proportionately more time is
> spent in coarse levels (although the total solve time is lower).
>> I like the ice paper and will try to get the contractor started on
>> reproducing those results.
>> -Chris
>> On Wed, Apr 10, 2013 at 1:13 PM, Nystrom, William D <wdn at lanl.gov> wrote:
>>> Sorry.  I overlooked that the URL was using git protocol.  My bad.
>>> Dave
>>> ________________________________________
>>> From: Jed Brown [five9a2 at gmail.com] on behalf of Jed Brown [jedbrown at mcs.anl.gov]
>>> Sent: Wednesday, April 10, 2013 12:10 PM
>>> To: Nystrom, William D; For users of the development version of PETSc; Chris Kees
>>> Subject: Re: [petsc-dev] examples/benchmarks for weak and strong scaling exercise
>>> "Nystrom, William D" <wdn at lanl.gov> writes:
>>>> Jed,
>>>> I tried cloning your tme-ice git repo as follows and it failed:
>>>> % git clone --recursive git://github.com/jedbrown/tme-ice.git tme_ice
>>>> Cloning into 'tme_ice'...
>>>> fatal: unable to connect to github.com:
>>>> github.com[0: 204.232.175.90]: errno=Connection timed out
>>>> I'm doing this from an xterm that allows me to clone petsc just fine.
>>> You're using https or ssh to clone PETSc, but the git:// to clone
>>> tme-ice.  The LANL network is blocking that port, so just use the https
>>> or ssh protocol.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130412/28762b9b/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130412/28762b9b/attachment-0001.obj>
