[petsc-dev] current snes and ts tutorials
Peter Brune brune at mcs.anl.gov
Thu Sep 20 18:01:50 CDT 2012
I'm bringing a bunch of the old TS ones into this millennium as we speak.
I'm trying to keep them instructive and as I go I can report on
duplications or ones that are nonworking or inappropriate as examples.
Maybe we should create a complementary directory to tests and examples that
makes clear that it's experimental.  That way we'd have a place we could
push cool things that we're working with while not creating a swamp for new
users to get stuck in.
- Peter
On Thu, Sep 20, 2012 at 5:56 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   A hodgepodge of ok and bad nonlinear and ODE examples.  I've tried to
> remove the most duplicative and irrelevant methods.
>    I'm trying to think of how we can organize and present these in a good
> way beginning users, presently it is just a swamp that people wander into.
>    Barry
> Barrys-MacBook-Pro:tutorials barrysmith$ grep help *.c | grep static | sed
> s/ex//g | sort -n
> 1.c:static char help[] = "Newton's method for a two-variable system,
> sequential.\n\n";
> 2.c:static char help[] = "Newton method to solve u'' + u^{2} = f,
> sequentially.\n\
> 3.c:static char help[] = "Newton methods to solve u'' + u^{2} = f in
> parallel.\n\
> 4.c:static char help[] = "Solves the Lane-Emden equation in a 2D
> rectangular\n\
> 5.c:static char help[] = "Bratu nonlinear PDE in 2d.\n\
> 5aspin.c:static char help[] = "Bratu nonlinear PDE in 2d.\n\
> 5s.c:static char help[] = "2d Bratu problem in shared memory parallel with
> SNES.\n\
> 7.c:static char help[] = "Solves the Stokes equation in a 2D rectangular\n\
> 8.c:static char help[] = "Solves the Bratu equation in a 2D rectangular\n\
> 9.c:static const char help[] = "Solves obstacle problem in 2D as a
> variational inequality.\n\
> 10.c:static const char help[] = "Uses analytic Jacobians to solve
> individual problems and a coupled problem.\n\n";
> 12.c:static char help[] = "Bratu nonlinear PDE in 2d.\n\
> 14.c:static char help[] = "Bratu nonlinear PDE in 3d.\n\
> 15.c:static const char help[] = "p-Bratu nonlinear PDE in 2d.\n\
> 18.c:static char help[] ="Nonlinear Radiative Transport PDE with multigrid
> in 2d.\n\
> 19.c:static char help[] = "Nonlinear driven cavity with multigrid in 2d.\n\
> 20.c:static char help[] ="Nonlinear Radiative Transport PDE with multigrid
> in 3d.\n\
> 21.c:static const char help[] = "Solves PDE optimization problem using
> full-space method, treats state and adjoint variables separately.\n\n";
> 22.c:static const char help[] = "Solves PDE optimization problem using
> full-space method, interlaces state and adjoint variables.\n\n";
> 25.c:static const char help[] ="Minimum surface problem in 2D.\n\
> 28.c:static const char help[] = "1D multiphysics prototype with analytic
> Jacobians to solve individual problems and a coupled problem.\n\n";
> 30.c:static const char help[] = "Steady-state 2D subduction flow, pressure
> and temperature solver.\n\
> 31.c:static char help[] = "Stokes Problem in 2d and 3d with simplicial
> finite elements.\n\
> 33.c:static char help[] = "Multiphase flow in a porous medium in 1d.\n\n";
> 35.c:static const char help[] = "-Laplacian u = b as a nonlinear
> problem.\n\n";
> 42.c:static char help[] = "Newton's method to solve a two-variable system
> that comes from the Rosenbrock function.\n\n";
> 43.c:static char help[] = "Newton's method to solve a many-variable system
> that comes from the 2 variable Rosenbrock function + trivial.\n\n";
> 46.c:static char help[] = "Surface processes in geophysics.\n\n";
> 48.c:static const char help[] = "Toy hydrostatic ice flow with multigrid
> in 3D.\n\
> 52.c:static const char help[] = "Testbed for FEM operations on the
> GPU.\n\n";
> 53.c:static const char help[] = "Read linear variational inequality from
> file and solve it.\n\n";
> 54.c:static char help[] = "Cahn-Hilliard-2d problem for constant mobility
> and triangular elements.\n\
> 55.c:static char help[] = "Allen-Cahn-2d problem for constant mobility and
> 56.c:static char help[] = "Stokes Problem in 2d and 3d with simplicial
> finite elements.\n\
> 57.c:static char help[] = "Stokes Problem in 2d and 3d with hahedral
> finite elements.\n\
> 58.c:static const char help[] = "Parallel version of the minimum surface
> area problem in 2D using DMDA.\n\
> 59.c:static const char help[] = "Tries to solve u`` + u^{2} = f for an
> easy case and an impossible case.\n\n";
> 60.c:static char help[] = "2D coupled Allen-Cahn and Cahn-Hilliard
> equation for constant mobility and triangular elements.\n\
> 61.c:static char help[] = "2D coupled Allen-Cahn and Cahn-Hilliard
> equation for constant mobility and triangular elements. Use periodic
> boundary condidtions.\n\
> 61gen.c:static char help[] = "Generates random numbers for radioactive
> events for 61.c.\n ./61gen [-random_seed <int>] \n";
> 61view.c:static const char help[] = "Loads data generated by 61 and VTK
> file suitable for Paraview or Visit.\n\n";
> 62.c:static char help[] = "Stokes Problem in 2d and 3d with simplicial
> finite elements.\n\
> 63.c:static char help[] = "1D coupled Allen-Cahn and Cahn-Hilliard
> equation for degenerate mobility and triangular elements.\n\
> 64.c:static char help[] = "1D coupled Allen-Cahn and Cahn-Hilliard
> equation for constant mobility. Only c_v and eta are considered.\n\
> 65.c:static char help[] = "2D coupled Allen-Cahn and Cahn-Hilliard
> 67.c:static char help[] = "Simple test for using advanced discretizations
> with DMDA\n\n\n";
> 70.c:static char help[] = "Poiseuille flow problem. Viscous, laminar flow
> in a 2D channel with parabolic velocity\n\
> 72.c:static char help[] = "Stokes Problem in 2d and 3d with hhedral finite
> elements.\n\
> 633D_DB.c:static char help[] = "3D coupled Allen-Cahn and Cahn-Hilliard
> 653D.c:static char help[] = "3D coupled Allen-Cahn and Cahn-Hilliard
> s/ex//g | sort -n
> 1.c:static char help[] ="Solves the time independent Bratu problem using
> pseudo-timestepping.";
> 2.c:static char help[] ="Solves a time-dependent nonlinear PDE. Uses
> implicit\n\
> 3.c:static char help[] ="Solves a simple time-dependent linear PDE (the
> heat equation).\n\
> 4.c:static char help[] ="Solves a simple time-dependent linear PDE (the
> heat equation).\n\
> 5.c:static char help[] ="Solves a simple time-dependent linear PDE (the
> heat equation).\n\
> 6.c:static char help[] ="Solves a simple time-dependent linear PDE (the
> heat equation).\n\
> 7.c:static char help[] = "Nonlinear, time-dependent PDE in 2d.\n";
> 8.c:static char help[] = "Nonlinear DAE benchmark problems.\n";
> 9.c:static const char help[] = "1D periodic Finite Volume solver in
> slope-limiter form with semidiscrete time stepping.\n"
> 10.c:static const char help[] = "1D nonequilibrium radiation diffusion
> with Saha ionization model.\n\n";
> 12.c:static char help[] = "Nonlinear, time-dependent PDE in 2d.\n";
> 13.c:static char help[] = "Time-dependent PDE in 2d. Simplified from 7.c
> for illustrating how to use TS on a structured domain. \n";
> 14.c:static const char help[] = "Toy hydrostatic ice flow with multigrid
> in 3D.\n\
> 15.c:static char help[] = "Time-dependent PDE in 2d. Modified from 13.c
> for illustrating how to solve DAEs. \n";
> 16.c:static char help[] = "Solves the van der Pol equation.\n\
> 17.c:static const char help[] = "Time-dependent PDE in 1d. Simplified from
> 15.c for illustrating how to solve DAEs. \n";
> 18.c:static const char help[] = "Isogeometric analysis of isothermal
> Navier-Stokes-Korteweg in 2D.";
> 19.c:static char help[] = "Solves the van der Pol DAE.\n\
> 20.c:static char help[] = "Solves the van der Pol equation.\n\
> 21.c:static char help[] ="Solves a time-dependent nonlinear PDE with lower
> and upper bounds on the interior grid points. Uses implicit\n\
> 22.c:static const char help[] = "Time-dependent advection-reaction PDE in
> 1d, demonstrates IMEX methods.\n";
> 23.c:static char help[] = "Cahn-Hilliard-2d problem for constant mobility
> 24.c:static char help[] = "Pseudotransient continuation to solve a
> many-variable system that comes from the 2 variable Rosenbrock function +
> trivial.\n\n";
> 25.c:static const char help[] = "Time-dependent Brusselator
> reaction-diffusion PDE in 1d. Demonstrates IMEX methods.\n";
> 26.c:static char help[] = "Transient nonlinear driven cavity in 2d.\n\
> 26aspin.c:static char help[] = "Transient nonlinear driven cavity in 2d
> using ASPIN.\n\n";
> 27.c:static char help[] = "Time-Dependent Reactive Flow ample in 2D with
> Darcy Flow";
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120920/c3e4a168/attachment.html>
