[petsc-dev] plans for testing examples?
Sun Sep 16 22:46:14 CDT 2012
On Sun, Sep 16, 2012 at 10:13 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    What are the various plans for running the test cases on examples?
>     As I've said before I'd really like each example to be self-contained
> which means its tests and its test results would all sit in the same file
> (so, for example, the file could trivially be moved to another directory
> location and the tests still work).  One way to do this is to have each
> example file to have a chunk of python code after the source that ran all
> the tests and then after that a chunk of all the outputs.   Having the test
> cases inside the makefile (or in some directory or gasp "single location
> specific file) and the output files in the output directory is, to me, not
> desirable.
It sounds like you are asking for something like Python's doctest for
executables.
http://docs.python.org/library/doctest.html
If the output was feasibly short, we could build a system this way.
>    Jed,  what is your horrible plan?
I wrote a parser for our makefile-based tests. It currently creates files
that describe tests like this:
with Executable('ex15.c', libs='PETSC_TS_LIB'):
    Test(id='1', args='-da_grid_x 20 -da_grid_y 20 -boundary 0
-ts_max_steps 10')
    Test(id='2', args='-da_grid_x 20 -da_grid_y 20 -boundary 0
-ts_max_steps 10 -Jtype 2', compare='ex15_1')
    Test(id='3', args='-da_grid_x 20 -da_grid_y 20 -boundary 1
-ts_max_steps 10')
    Test(id='4', np=2, args='-da_grid_x 20 -da_grid_y 20 -boundary 1
-ts_max_steps 10')
    Test(id='5', args='-da_grid_x 20 -da_grid_y 20 -boundary 0
-ts_max_steps 10 -Jtype 1', compare='ex15_1')
I would the "id" field to use more descriptive names when appropriate so
these numbers are just the inherited names. This snippet of Python
registers the executable and the associated tests in a global index (will
probably make at a sqlite database). The test result can be reported back
to the database. I wrote most of a parallel executor with active progress
monitoring, similar to nose-progressive, but not all the pieces are playing
nicely together yet.
Me eventual plan is to be able to batch up the test results, which will
include basic timing information, and report it back to a central server so
we can keep a log. That could be done with buildbot or Jenkins, which
fulfill most of our needs for a "dashboard", but lack a good database query
API.
Test specification, which seems to be what you are most concerned with,
could also be via "doctests". The main thing is that if you execute the
test script, it first updates its database with all executables and tests
in subdirectories (specified any way we like), then does whatever
operations you ask for (building, testing, etc).
>    Matt, what is your horrible plan?
>     Can we converge to something agreeable to all?
>    Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120916/9016fc39/attachment.html>
