[petsc-dev] migrating repos from petsc.cs.iit.edu to bitbucket.org
Shri abhyshr at hawk.iit.edu
Sun Nov 18 22:06:04 CST 2012
Satish,
   What's happening with the private repos hosted on petsc.cs.iit.edu? I had a private repo there for my Ph.D. project (ts_emt). Although I don't need it anymore, I just wanted to check if it was backed up somehow.
Shri
On Nov 18, 2012, at 9:43 PM, Satish Balay wrote:
> On Sat, 17 Nov 2012, Barry Smith wrote:
>> On Nov 17, 2012, at 10:52 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> On Sat, Nov 17, 2012 at 11:48 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> [I don't think its appropriate to make this change for a petsc-3.3 patch update.]
>>> Okay, what if we start using subrepos with petsc-dev -> buildsystem and let petsc-release continue to depend on a buildsystem-release without use of subrepo?
>>   I would not try to force the build system subrepo into petsc-release.   In fact I would advocate keeping all the old petsc-release-xxx and ONLY doing the petsc-release with bookmarks (or whatever they care called) going forward from the next release, so petsc-release would only contain petsc-3.4 and later explicitly it would not have bookmarks (or whatever they are called) for petsc-3.3  petsc-3.2 …..
>>  We are changing to a new model but the old stuff stays under the old model. (Hence petsc-release won't even exist until the next release.)
> ok. removed petsc-release,buildsystem-release.
> And migrated:
> buildsystem-2.3.1
> buildsystem-2.3.2
> buildsystem-2.3.3
> buildsystem-3.0.0
> buildsystem-3.1
> buildsystem-3.2
> buildsystem-3.3
> petsc-2.3.1
> petsc-2.3.2
> petsc-2.3.3
> petsc-3.0.0
> petsc-3.1
> petsc-3.2
> petsc-3.3
> And the following repos aswell:
> win32fe
> cll
> ams
> ctetgen
> [apart from externalpackages, tutorials] the follwing repos exist in
> the backups. Do any of them need to go into bitbucket.org/petsc?
> Allen-Cahn-2D
> BuildSystem-txcorp
> Cahn-Hillard-1D
> Cahn-Hillard-2D
> composing-nonlinear-solvers
> crap-test
> cudaFMM
> dft
> dft-fft
> dft-log
> dft-mg
> dft-rfd
> documentation
> FMM
> FMM-dev
> lwang-dev
> multiphysics
> petsc-dev-new
> petsc-dev-pthread
> petsc-dev-tmp
> petsc-dev-txcorp
> petsc-gpu
> petscpathlib
> petsc-subtest
> powerlaw
> pthread-paper
> reacting_flow
> simpleConfigure
> petsc-dev-ts
> There are also repos in externalpackages and tutorials that need migrating.
> externalpackages/blacs-dev
> externalpackages/Chaco-2.2
> externalpackages/ctetgen
> externalpackages/f2cblaslapack-3.1.1
> externalpackages/fblaslapack-3.1.1
> externalpackages/hdf5-1.8.4
> externalpackages/hdf5-1.8.8
> externalpackages/hypre-2.7.0b
> externalpackages/hypre-2.8.0b
> externalpackages/lgrind-dev
> externalpackages/metis-5.0.2
> externalpackages/mumps
> externalpackages/MUMPS_4.10.0
> externalpackages/numdiff-5.2.1
> externalpackages/parmetis-4.0.2
> externalpackages/pARMS_3.2
> externalpackages/PLAPACKR32
> externalpackages/Prometheus-1.8.10
> externalpackages/qblaslapack
> externalpackages/README
> externalpackages/SCALAPACK-1.7
> externalpackages/scotch_5.1.12b_esmumps
> externalpackages/sowing-1.1.16
> externalpackages/spooles-2.2
> externalpackages/superlu_dist-3.0
> externalpackages/Triangle
> externalpackages/UMFPACK-5.4
> externalpackages/UMFPACK-5.5.1
> utorials/ACTS07
> tutorials/Columbia06
> tutorials/CSCS10
> tutorials/GUCAS09
> tutorials/GUCAS10
> tutorials/mercurial
> tutorials/PCFD07
> tutorials/SCAT07
> tutorials/SimpleTutorial
> tutorials/summer11
> tutorials/summer11-bigchange
> tutorials/TACC08
> tutorials/TACC09Examples
> tutorials/TACC12
> tutorials/vecfem
> Satish
