[petsc-dev] Fwd: [mumps-dev] support for distributed right-hand vectors?
Alexander Grayver agrayver at gfz-potsdam.de
Tue Nov 13 12:53:07 CST 2012
On 13.11.2012 14:11, Jack Poulson wrote:
> I can't help but interject. Sparse direct solvers are not nonscalable
> "in general". General purpose solvers have to worry about pivoting,
> which greatly complicates the factorization and tends to get in the
> way of scalability. Several sparse-direct solvers use one-dimensional
> frontal distributions (e.g., MUMPS and SPOOLES) in order to simplify
> pivoting, though MUMPS uses a two-dimensional distribution at the root
> front.
> It is well-known how to make multifrontal Cholesky factorization
> scalable (for example, see one of the many papers by
> Gupta/Karypis/Kumar/Joshi from the 90's). Making multifrontal
> triangular solves scalable is another matter.
Jack,
Thanks for the comment.
Could you comment on or give a reference to the blow up in memory one
observes when running general purpose direct solvers in parallel?
P.S. Does Clique support pivoting?
Alexander
