[petsc-dev] release preparation
Thu May 31 01:17:04 CDT 2012
I've now created the release repos - so petsc-dev is now open for all
commits.
[If you've accumulated petsc-dev related commits - rebasing them with
current petsc-dev - before pushing would be good.]
Release related commits should now go to the release repo [and not
directly to petsc-dev]. Please use the usual release repo
workflow. i.e:
- clone the release repos
- commit/push [to release-repos]
- from petsc-dev clone - pull/merge release commits and push to petsc-dev.
[or defer this last step to me until the release]
ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/petsc-3.3
ssh://petsc@petsc.cs.iit.edu//hg/petsc/releases/BuildSystem-3.3
Satish
On Thu, 17 May 2012, Barry Smith wrote:
>   petsc-dev folks,
>     Recall that we are in a phase of a code freeze that means do not push random new code to petsc-dev, push only bug fixes and clean up to petsc-dev.  By all means keep on with code development, just don't push the new stuff to petsc-dev.
>      We hope to make the release repository (and then tarball) next Wednesday May 23. So please do be checking the nightly builds and making fixes to petsc-dev.
>    Barry
> Note: threaded code and GPU code will not be supported with the release (users should continue to use petsc-dev after the release) so fixes/extensions to those things are not needed and shouldn't be pushed to petsc-dev at the moment.
