[petsc-dev] PCASM uses DMCreateDecomposition which splits field, NOT expected behavior
Sat May 26 22:38:50 CDT 2012
On Sat, May 26, 2012 at 10:24 PM, Dmitry Karpeev <karpeev at mcs.anl.gov>wrote:
> How about having a DM-specific function for that designation?
> DMXXXGetFieldSplits()/DMXXXGetDomainDecompositions(), for example?
For the C interface, maybe configure a named set with DMXxxSet... and tell
PCASM to use it. For the options database interface, maybe have the option
processed by DMXxx code instead of by PCASM. I don't know, this might be
just as bad.
> I think that would work, if the implementation defined only a small number
> of decompositions.
> If instead there is a short grammar defining well-formed strings naming
> such decompositions, I'm not sure how to
> communicate that to the user, other than in documentation.  I have
> DMLibMeshGetVars() to return all vars.  FieldSplits
> can be defined as arbitrary groupings of those.  Each split will then
> advertise only the vars in the groupings that defines the split.
I still don't know what to do about a nonlinear change of basis.
Advertising var names seems reasonable to me.
Note that ASM domains are essentially vertex-oriented which is different
from element-centered domains (natural for non-overlapping methods).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120526/3ded9a34/attachment.html>
