[petsc-dev] Multigrid is confusing
Thu May 24 15:39:16 CDT 2012
On Thu, May 24, 2012 at 4:16 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, May 24, 2012 at 3:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> Absolutely. And if it turns out to be too much of a pain to write and
>> maintain such a kernel there is something wrong with our programming model
>> and code development system. The right system should make all the
>> complexity fall away; when the complexity becomes too much of a bear you
>> know you have the wrong system.
> So do we manage blocks using internal C++ templates, "templates in C", C
> generated using some other system (m4 anyone?), or something else entirely?
Yes! Finally, we acknowledge that this a problem.
1) C++ templates are not a solution to anything. ANYTHING.
2) I am assuming "templates in C" would work somewhat like a templating
engine.
    I tried this for the last TOMS paper with Andy. Its was just not a big
payoff for
    the work put in, and definitely did not justify incorporating another
package.
3) I prefer C generated from another system, like the one I use for FEM
(which I am
    not attached to). We will definitely need this for GPU kernels, and I
am guessing
    thread kernels if they are going to be worth something.
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120524/9e5feaa9/attachment.html>
