[petsc-dev] Multigrid is confusing
Thu May 24 15:16:01 CDT 2012
On Thu, May 24, 2012 at 3:10 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> Absolutely. And if it turns out to be too much of a pain to write and
> maintain such a kernel there is something wrong with our programming model
> and code development system. The right system should make all the
> complexity fall away; when the complexity becomes too much of a bear you
> know you have the wrong system.
So do we manage blocks using internal C++ templates, "templates in C", C
generated using some other system (m4 anyone?), or something else entirely?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120524/de68929d/attachment.html>
