[petsc-dev] anyone feel like fixing a bug?
Mark F. Adams mark.adams at columbia.edu
Wed May 23 09:27:23 CDT 2012
On May 23, 2012, at 9:36 AM, Barry Smith wrote:
> On May 22, 2012, at 9:32 PM, Jed Brown wrote:
>> Well, here's the problem:
>> MatSetBlockSize() used to call mat->ops->setblocksize() which the MPI matrices forwarded down to their seq submatrices.
>> But then this patch removed that behavior so MatSetBlockSize() is processed immediately and not forwarded down.
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/80ec81eb9db9
>> Since the Seq inner matrices have different PetscLayouts, they don't inherit the block sizes set on their parent.
>> Barry, why did you remove this MatOp? How do you want the MPI matrices to forward block sizes now?
>   Blocksize is now suppose to be known "early" now. That is, you cannot change it after MatSetUp() is called. It is the job of each matrix implementation to use the already set block size in the appropriate way. Generally this means before the "Seq" matrices are created or finalized.  One could possible arrange moving the blocksize information down during the MatSetUp() of that implementation or the MatXXXXSetPreallocation() or when the inner Mat objects are created.
I have gone through and done this manual inheritance, but 1) I may have missed some and 2) there were some that I could not figure out how to do.  I'm back online today and can work on this.  I did leave some comments in the form of SetBlockSize statements that are commented out in places were I had trouble.
>    If you tell me the EXACT change of events of the "inner" block size not being set properly I can take a look at it.
>   Barry
>> On Sat, May 19, 2012 at 10:57 AM, Mark F. Adams <mark.adams at columbia.edu> wrote:
>> I'm going to be tied up for a few days, should be able to get to this Wed., if not sooner, but if anyone wants to take a crack at it, here it is. This is run with 8 procs.
>> Mark
>> ==51037== Command: ./ex56 -ne 19 -alpha 1.e-3 -ksp_type cg -ksp_monitor -ksp_max_it 15 -pc_type gamg -pc_gamg_type agg -pc_gamg_agg_nsmooths 1 -pc_gamg_verbose 2 -ksp_converged_reason -options_left -theta -30.0 -epsilon .01 -blob_center 0.,0. -pc_gamg_threshold .0 -pc_gamg_coarse_eq_limit 100 -use_coordinates -out_verbose 2 -aggmg_smooths 1 -mg_levels_ksp_type chebyshev -mg_levels_ksp_chebyshev_estimate_eigenvalues 0,0.2,0,1.1 -mg_levels_pc_type pbjacobi -mg_levels_ksp_max_it 1
>> ==51039== Invalid read of size 8
>> ==51039==    at 0x91E38B: PCApply_PBJacobi_3 (pbjacobi.c:81)
>> ==51039==    by 0xA0FE23: PCApply (precon.c:384)
>> ==51039==    by 0xADA9B2: KSPInitialResidual (itres.c:64)
>> ==51039==    by 0xA7EA39: KSPSolve_GMRES (gmres.c:230)
>> ==51039==    by 0xAB3CA2: KSPSolve (itfunc.c:446)
>> ==51039==    by 0xAA6FF8: KSPSolve_Chebyshev (cheby.c:269)
>> ==51039==    by 0x9ECD2F: PCMGMCycle_Private (mg.c:20)
>> ==51039==    by 0x9F0BEF: PCApply_MG (mg.c:321)
>> ==51039==    by 0xA43EBF: KSPSolve_CG (cg.c:139)
>> ==51039==    by 0x4805: main (in ./ex56)
>> ==51039==  Address 0x27f4c90 is 0 bytes after a block of size 24,032 alloc'd
>> ==51039==    at 0x1B2AF16: malloc (vg_replace_malloc.c:236)
>> ==51039==    by 0x8A8C7: PetscMallocAlign (mal.c:37)
>> ==51039==    by 0x61E602: MatInvertBlockDiagonal_SeqAIJ (aij.c:2816)
>> ==51039==    by 0x2F0AC3: MatInvertBlockDiagonal (matrix.c:9280)
>> ==51039==    by 0x6D1494: MatInvertBlockDiagonal_MPIAIJ (mpiaij.c:2981)
>> ==51039==    by 0x920A85: PCSetUp_PBJacobi (pbjacobi.c:213)
>> ==51039==    by 0xA1783B: PCSetUp (precon.c:832)
>> ==51039==    by 0xAB2125: KSPSetUp (itfunc.c:278)
>> ==51039==    by 0x9F536C: PCSetUp_MG (mg.c:678)
>> ==51039==    by 0x98C26C: PCSetUp_GAMG (gamg.c:984)
>> ==51039==    by 0x46AD: main (in ./ex56)
>> ==51039==
