[petsc-dev] API changes in MatIS
Fri May 11 12:53:01 CDT 2012
I don't like this idea of the matrix type determining the algorithm, I'd
rather choose the algorithm.
Can we decouple it by building the prolongation operator P whose columns
are harmonic extension of the coarse nodes? Then the coarse operator looks
like P^T A P just like multigrid (for which we have a matop) instead of
looking like a Schur complement.
On May 10, 2012 2:42 PM, "Stefano Zampini" <stefano.zampini at gmail.com>
wrote:
> This is to do recursive BDDC or what?
> Yes. When creating the BDDC coarse matrix, now the code has three 3 options
> A) coarse matrix is a MATIS -> multilevel BDDC
> B) coarse matrix is SEQAIJ -> one level BDDC with only one proc (or all)
> solving directly the coarse problem
> C) coarse matrix is MPIAIJ -> one level  BDDC with a parallel direct solve
> I think that PCREDUNDANT can do the job in both cases of options B if the
> matrix would be parallel.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120511/89fdc29f/attachment.html>
