[petsc-dev] discrepancy with bcgs, mpi, cusp, and no preconditioning
Thu May 10 14:49:55 CDT 2012
On Thu, May 10, 2012 at 3:45 PM, Chetan Jhurani <chetan.jhurani at gmail.com>wrote:
> Hi wizards of "->ops->" indirections,
> I'm trying to use bcgs without preconditioning, for now, and
> the iterations using "-vec_type cusp -mat_type mpiaijcusp" don't
> match serial or non-GPU options.  I've attached the test program
> and the 4 outputs (serial/parallel + CPU/GPU).  All this is
> with petsc-dev downloaded now and real scalars.
> Only the parallel GPU results are different starting from
> third residual norm seen in results.txt.  The other three match
> one another.  Am I doing something wrong?
> fbcgs (bcgs with -ksp_bcgs_flexible) works fine with all the
> serial/parallel or CPU/GPU options I've tried.
> Let me know if you need the matrix, rhs, and initial guess
> binary files that are read in by the test program.
That would be great. This looks like a bug that should be tracked down.
    MAtt
> Thanks,
> Chetan
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120510/26dfa2ac/attachment.html>
