[petsc-dev] discrepancy with bcgs, mpi, cusp, and no preconditioning
Chetan Jhurani chetan.jhurani at gmail.com
Thu May 10 14:45:30 CDT 2012
Hi wizards of "->ops->" indirections,
I'm trying to use bcgs without preconditioning, for now, and
the iterations using "-vec_type cusp -mat_type mpiaijcusp" don't
match serial or non-GPU options.  I've attached the test program
and the 4 outputs (serial/parallel + CPU/GPU).  All this is
with petsc-dev downloaded now and real scalars.
Only the parallel GPU results are different starting from
third residual norm seen in results.txt.  The other three match
one another.  Am I doing something wrong?
fbcgs (bcgs with -ksp_bcgs_flexible) works fine with all the
serial/parallel or CPU/GPU options I've tried.
Let me know if you need the matrix, rhs, and initial guess
binary files that are read in by the test program.
Chetan
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120510/d2a5c52f/attachment.ksh>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120510/d2a5c52f/attachment.txt>
