[petsc-dev] Error during KSPDestroy
Alexander Grayver agrayver at gfz-potsdam.de
Mon May 7 02:16:39 CDT 2012
On 06.05.2012 22:24, Barry Smith wrote:
>    Alexander,
>       I cannot reproduce this on my mac with 3 different blas/lapack.
Barry,
I'm surprised. I ran it on my home PC with ubuntu and PETSc configured
from scratch as following:
--download-mpich --with-fortran-interfaces=1 --download-scalapack
--download-blacs --with-scalar-type=complex --download-blas-lapack
--with-precision=double
And it's still there.
Please note that all my numbers are complex.
>       Could you please run the case below but with --download-f-blas-lapack   (you forgot the -f last time)? Send us the valgrind results. This will tell use the exact line number in dlasq3() that is triggering the bad read.
I did:
./configure --with-petsc-arch=openmpi-intel-complex-debug-c
--download-scalapack --download-blacs --download-f-blas-lapack
--with-precision=double --with-scalar-type=complex
And then valgrind program. The first message from log:
==27656== Invalid write of size 8
==27656==    at 0x15A8E9E: dlasq2_ (dlasq2.f:215)
==27656==    by 0x15A83A4: dlasq1_ (dlasq1.f:135)
==27656==    by 0x158ACEC: zbdsqr_ (zbdsqr.f:225)
==27656==    by 0x154EC27: zgesvd_ (zgesvd.f:2038)
==27656==    by 0x695DD3: KSPComputeExtremeSingularValues_GMRES
(gmreig.c:46)
==27656==    by 0x69DD76: KSPComputeExtremeSingularValues (itfunc.c:47)
==27656==    by 0x44E98C: main (solveTest.c:62)
==27656==  Address 0xfad2d98 is 8 bytes before a block of size 832 alloc'd
==27656==    at 0x4C25D66: memalign (vg_replace_malloc.c:694)
==27656==    by 0x4B642B: PetscMallocAlign (mal.c:30)
==27656==    by 0x687775: KSPSetUp_GMRES (gmres.c:73)
==27656==    by 0x69FE4A: KSPSetUp (itfunc.c:239)
==27656==    by 0x6A2058: KSPSolve (itfunc.c:402)
==27656==    by 0x44E969: main (solveTest.c:61)
Please find full log attached.
>      Barry
> On May 6, 2012, at 9:16 AM, Alexander Grayver wrote:
>> On 06.05.2012 15:34, Matthew Knepley wrote:
>>> On Sun, May 6, 2012 at 9:24 AM, Alexander Grayver<agrayver at gfz-potsdam.de>  wrote:
>>> Hm, valgrind gives a lot of output like that (see full log in previous message):
>>> Can you run this with --download-f-blas-lapack? This sounds much more like an MKL bug.
>> I did:
>> --download-scalapack --download-blacs --download-blas-lapack --with-precision=double --with-scalar-type=complex
>> The error is still there. I checked "ldd solveTest", mkl is not used for sure. This is not an MKL problem I guess:
>> ==13600== Invalid read of size 8
>> ==13600==    at 0x58636AF: dlasq3_ (in /usr/local/lib/liblapack.so.3.2.2)
>> ==13600==    by 0x5862C84: dlasq2_ (in /usr/local/lib/liblapack.so.3.2.2)
>> ==13600==    by 0x5861F2C: dlasq1_ (in /usr/local/lib/liblapack.so.3.2.2)
>> ==13600==    by 0x571A479: zbdsqr_ (in /usr/local/lib/liblapack.so.3.2.2)
>> ==13600==    by 0x57466A7: zgesvd_ (in /usr/local/lib/liblapack.so.3.2.2)
>> ==13600==    by 0x694687: KSPComputeExtremeSingularValues_GMRES (gmreig.c:46)
>> ==13600==    by 0x69C62A: KSPComputeExtremeSingularValues (itfunc.c:47)
>> ==13600==    by 0x44E02C: main (solveTest.c:62)
>> ==13600==  Address 0x10826b90 is 16 bytes before a block of size 832 alloc'd
>> ==13600==    at 0x4C25D66: memalign (vg_replace_malloc.c:694)
>> ==13600==    by 0x4B5ACB: PetscMallocAlign (mal.c:30)
>> ==13600==    by 0x686181: KSPSetUp_GMRES (gmres.c:73)
>> ==13600==    by 0x69E6FE: KSPSetUp (itfunc.c:239)
>> ==13600==    by 0x6A090C: KSPSolve (itfunc.c:402)
>> ==13600==    by 0x44E009: main (solveTest.c:61)
>> The weird thing is that the it gives correct result, so zgesvd works fine.
>> And also running this program with 10 iterations in valgrind doesn't produce error. The low above is with 100 iterations.
>> Without valgrind the error is always there.
>> Regards,
>> Alexander
Alexander
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120507/54a035e5/attachment.bin>
