[petsc-dev] Error during KSPDestroy
Sun May 6 15:24:28 CDT 2012
  Alexander,
     I cannot reproduce this on my mac with 3 different blas/lapack.
     Could you please run the case below but with --download-f-blas-lapack   (you forgot the -f last time)? Send us the valgrind results. This will tell use the exact line number in dlasq3() that is triggering the bad read.
    Barry
On May 6, 2012, at 9:16 AM, Alexander Grayver wrote:
> On 06.05.2012 15:34, Matthew Knepley wrote:
>> On Sun, May 6, 2012 at 9:24 AM, Alexander Grayver <agrayver at gfz-potsdam.de> wrote:
>> Hm, valgrind gives a lot of output like that (see full log in previous message):
>> Can you run this with --download-f-blas-lapack? This sounds much more like an MKL bug.
> I did:
> --download-scalapack --download-blacs --download-blas-lapack --with-precision=double --with-scalar-type=complex
> The error is still there. I checked "ldd solveTest", mkl is not used for sure. This is not an MKL problem I guess:
> ==13600== Invalid read of size 8
> ==13600==    at 0x58636AF: dlasq3_ (in /usr/local/lib/liblapack.so.3.2.2)
> ==13600==    by 0x5862C84: dlasq2_ (in /usr/local/lib/liblapack.so.3.2.2)
> ==13600==    by 0x5861F2C: dlasq1_ (in /usr/local/lib/liblapack.so.3.2.2)
> ==13600==    by 0x571A479: zbdsqr_ (in /usr/local/lib/liblapack.so.3.2.2)
> ==13600==    by 0x57466A7: zgesvd_ (in /usr/local/lib/liblapack.so.3.2.2)
> ==13600==    by 0x694687: KSPComputeExtremeSingularValues_GMRES (gmreig.c:46)
> ==13600==    by 0x69C62A: KSPComputeExtremeSingularValues (itfunc.c:47)
> ==13600==    by 0x44E02C: main (solveTest.c:62)
> ==13600==  Address 0x10826b90 is 16 bytes before a block of size 832 alloc'd
> ==13600==    at 0x4C25D66: memalign (vg_replace_malloc.c:694)
> ==13600==    by 0x4B5ACB: PetscMallocAlign (mal.c:30)
> ==13600==    by 0x686181: KSPSetUp_GMRES (gmres.c:73)
> ==13600==    by 0x69E6FE: KSPSetUp (itfunc.c:239)
> ==13600==    by 0x6A090C: KSPSolve (itfunc.c:402)
> ==13600==    by 0x44E009: main (solveTest.c:61)
> The weird thing is that the it gives correct result, so zgesvd works fine.
> And also running this program with 10 iterations in valgrind doesn't produce error. The low above is with 100 iterations.
> Without valgrind the error is always there.
> Regards,
> Alexander
