[petsc-dev] Error in make test
Stefano Zampini stefano.zampini at gmail.com
Sat May 5 10:01:37 CDT 2012
I reverted to 23244.
2012/5/5 Shri <abhyshr at mcs.anl.gov>
> I've disabled the threadcomm code temporarily, so hopefully your code
> should run as before now. Please pull and retry.
> Thanks,
> Shri
> Same error on make test.
> Moreover, I got some mpi errors running my fortran codes and PETSc doesn't
> show the traceback
> I can only see that the problem occurs in PetscInitialize
> Here is the cryptic output from MPI (openmpi.1.4.5)
> [neo155:25438] *** An error occurred in MPI_Attr_get
> [neo155:25438] *** on communicator MPI COMMUNICATOR 3 DUP FROM 1
> [neo155:25438] *** MPI_ERR_OTHER: known error not in list
> [neo155:25438] *** MPI_ERRORS_ARE_FATAL (your MPI job will now abort)
>> I pushed some changes to fix these errors. Can you please pull and retry.
>> I had pulled some hours ago from
>> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/61898f35c333 and obtained
>> the following error on make test
>> [0]PETSC ERROR: PetscCommDuplicate() line 200 in
>> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/sys/objects/tagm.c
>> [0]PETSC ERROR: PetscHeaderCreate_Private() line 51 in
>> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/sys/objects/inherit.c
>> [0]PETSC ERROR: SNESCreate() line 1293 in
>> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/snes/interface/snes.c
>> [0]PETSC ERROR: main() line 102 in src/snes/examples/tutorials/ex19.c
>> I've just pulled and got the following error after typing make test
>> [0]PETSC ERROR: PetscCommDestroy() line 246 in
>> [0]PETSC ERROR: PetscThreadCommFinalizePackage() line 36 in
>> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/sys/threadcomm/interface/dlregisthreadcomm.c
>> [0]PETSC ERROR: PetscRegisterFinalizeAll() line 313 in
>> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/sys/objects/destroy.c
>> [0]PETSC ERROR: PetscFinalize() line 1080 in
>> /work/adz/zampini/MyWorkingCopyOfPetsc/petsc-dev/src/sys/objects/pinit.
>> I did not configure for a threaded version of PETSc.
>> Stefano
> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120505/0aca0168/attachment.html>
