[petsc-dev] Petsc VecCopy code.
Fri May 4 13:40:31 CDT 2012
On Fri, May 4, 2012 at 2:27 PM, Yoo, Andy <yoo2 at llnl.gov> wrote:
> Hi,****
> I have written a two-dimensional MatVec routine (
> http://dl.acm.org/citation.cfm?id=2063469) a while ago.
Any chance of getting that into PETSc proper?
> Now, I am noticing there is a small memory leak that appears to come from
> VecCopy. It is small, as it only appears like after 300000 MatVecs.****
> I looked at the Petsc sources, but was not able to locate the default copy
> function for VecMPI.****
> Can you please point me to the right direction?
Its here:
http://petsc.cs.iit.edu/petsc/petsc-dev/annotate/95406d5a1c14/src/vec/vec/impls/seq/bvec2.c#l190
set here in the vtable:
http://petsc.cs.iit.edu/petsc/petsc-dev/annotate/95406d5a1c14/src/vec/vec/impls/mpi/pbvec.c#l111
   Matt
> Thank you for your help in advance.****
> Andy Yoo, Ph.D.****
> Center for Applied Scientific Computing****
> Lawrence Livermore National Laboratory****
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120504/25a3d012/attachment.html>
