[petsc-dev] Petsc VecCopy code.
Yoo, Andy yoo2 at llnl.gov
Fri May 4 13:27:24 CDT 2012
I have written a two-dimensional MatVec routine (http://dl.acm.org/citation.cfm?id=2063469) a while ago.
Now, I am noticing there is a small memory leak that appears to come from VecCopy. It is small, as it only appears like after 300000 MatVecs.
I looked at the Petsc sources, but was not able to locate the default copy function for VecMPI.
Can you please point me to the right direction?
Thank you for your help in advance.
Andy Yoo, Ph.D.
Center for Applied Scientific Computing
Lawrence Livermore National Laboratory
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120504/53db2a7d/attachment.html>
