[petsc-dev] PetscLogView vs. -log_summary
Thu Jun 21 14:55:10 CDT 2012
On Thu, Jun 21, 2012 at 1:11 PM, Blaise Bourdin <bourdin at math.lsu.edu>wrote:
> Hi,
> PetscLogView does not display the same amount of information as running
> with -log_summary. In the "summary of stages" section, the former contains
> only information on the main stage while the later contains much more.
> Add the following block at the end of src/snes/examples/tutorials/ex1.c,
> for instance, to see what I mean
>  PetscViewer viewer;
>  ierr =
> PetscViewerASCIIOpen(PETSC_COMM_WORLD,"ex1-log.py",&viewer);CHKERRQ(ierr);
>  ierr = PetscLogViewPython(viewer);CHKERRQ(ierr);
>  ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr);
>  ierr =
> PetscViewerASCIIOpen(PETSC_COMM_WORLD,"ex1-log.txt",&viewer);CHKERRQ(ierr);
>  ierr = PetscLogView(viewer);CHKERRQ(ierr);
>  ierr =
> PetscLogPrintDetailed(PETSC_COMM_WORLD,"ex1-logdetailed.txt");CHKERRQ(ierr);
> Is this a bug or a feature? Is there a way to get the same output as
> -log_summary in a file, without printing it to stdout?
-log_summary just calls PetscLogView(). I am not sure how there could be a
problem. I will run it. However, can you
just use
  -log_summary <filename>
     Matt
> Blaise
> Department of Mathematics and Center for Computation & Technology
> Louisiana State University, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276
> http://www.math.lsu.edu/~bourdin
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120621/9ee466b7/attachment.html>
