[petsc-dev] error reading binary file
Mark F. Adams mark.adams at columbia.edu
Tue Jun 12 16:45:24 CDT 2012
On Jun 12, 2012, at 5:33 PM, Jed Brown wrote:
> On Tue, Jun 12, 2012 at 4:35 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> And I now get the following error when I try to run this in parallel.
> Note, Blaise, I do not have coordinates, so perhaps you could check that you still get divergence w/o coordinates.  (I don't need anything else form you)
> Did you apply the patch? I ran that code in parallel using ./ex10 -f0 binaryoutput-sym
Satish beat me to it.  I still get the same error ... did you use -mat_block_size 3?
I will look in to further.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120612/09c282d1/attachment.html>
