[petsc-dev] error reading binary file
Tue Jun 12 16:33:51 CDT 2012
On Tue, Jun 12, 2012 at 4:35 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> And I now get the following error when I try to run this in parallel.
> Note, Blaise, I do not have coordinates, so perhaps you could check that
> you still get divergence w/o coordinates.  (I don't need anything else form
> you)
Did you apply the patch? I ran that code in parallel using ./ex10 -f0
binaryoutput-sym
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120612/ea583ba4/attachment.html>
