[petsc-dev] error reading binary file
Tue Jun 12 14:31:08 CDT 2012
On Wed, Jun 13, 2012 at 3:25 AM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> On Jun 12, 2012, at 2:57 PM, Matthew Knepley wrote:
> On Wed, Jun 13, 2012 at 2:57 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> On Tue, Jun 12, 2012 at 1:59 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
>>> How does one do that?  Blaise generated this mat/vec.
>> Set a prefix in the info file (done automatically when you write it) and
>> set a prefix on the Vec before you read it.
> I think its even simpler in this case. The option is coming too late. Give
> it explicitly on the command line.
> Still not sure what you mean.  I added -vecload_block_size 3 to the
> command line and I got the same error.
I thought there would be a -vec_block_size option, but alas its missing.
Can you check in the debugger
when the block size is getting set? I cannot find it in VecSetFromOptions().
   Matt
> Also, shouldn't this just work? Blaise wrote a binary fine and I'm using
> ex10 to read it.  We are both using petsc-dev presumably.
> Mark
>    Matt
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120613/0c31ab22/attachment.html>
