[petsc-dev] error reading binary file
Mark F. Adams mark.adams at columbia.edu
Tue Jun 12 14:25:04 CDT 2012
On Jun 12, 2012, at 2:57 PM, Matthew Knepley wrote:
> On Wed, Jun 13, 2012 at 2:57 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Tue, Jun 12, 2012 at 1:59 PM, Mark F. Adams <mark.adams at columbia.edu> wrote:
> How does one do that?  Blaise generated this mat/vec.
> Set a prefix in the info file (done automatically when you write it) and set a prefix on the Vec before you read it.
> I think its even simpler in this case. The option is coming too late. Give it explicitly on the command line.
Still not sure what you mean.  I added -vecload_block_size 3 to the command line and I got the same error.
Also, shouldn't this just work? Blaise wrote a binary fine and I'm using ex10 to read it.  We are both using petsc-dev presumably.
>    Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120612/21a96ef7/attachment.html>
