[petsc-dev] Fwd: [petsc-maint #119133] petsc-dev configure crash
Thu Jun 7 01:28:21 CDT 2012
On Wed, 6 Jun 2012, Satish Balay wrote:
> ssh://petsc@petsc.cs.iit.edu//home/petsc/petsc-buildsystem-dev
> Just to clarify - this is a play-repo - i.e all edits/clones should be
> discarded later on.
ok - rebase behaves differently with subrepos. How is it supporsed to work?
With separate repos - I can do:
hg commit [local changes]
hg pull --rebase  [automatically rebases the commit
hg push
With sub-repos - I see the following:
Satish
[balay at maverick petsc-buildsystem-dev]$ hg version
Mercurial Distributed SCM (version 2.2.1)
[balay at maverick petsc-buildsystem-dev]$ hg -q in -S
23599:7c0333892302
23600:007d9928edc8
2828:1c53f750b541
2829:6548b4f26bd1
2830:03ab1f7aeb3a
2831:6ab6f1ae4aff
[balay at maverick petsc-buildsystem-dev]$ hg st -S
[balay at maverick petsc-buildsystem-dev]$ vi config/examples/asterix/asterix64.py config/BuildSystem/config/packages/BlasLapack.py
2 files to edit
[balay at maverick petsc-buildsystem-dev]$ hg status -S
M config/BuildSystem/config/packages/BlasLapack.py
M config/examples/asterix/asterix64.py
[balay at maverick petsc-buildsystem-dev]$ hg commit -S
committing subrepository config/BuildSystem
.hgsubstate
committed changeset 23599:a7b4f38e3075
[balay at maverick petsc-buildsystem-dev]$ hg -q out -S
23599:a7b4f38e3075
2828:358afb29fe48
[balay at maverick petsc-buildsystem-dev]$ hg pull --rebase
running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/petsc-buildsystem-dev serve --stdio'
pulling from ssh://petsc@petsc.cs.iit.edu//home/petsc/petsc-buildsystem-dev
searching for changes
adding changesets
adding manifests
adding file changes
added 2 changesets with 3 changes to 2 files (+1 heads)
resolving manifests
getting .hgsubstate
running ssh petsc at petsc.cs.iit.edu 'hg -R /home/petsc/BuildSystem-subrepo serve --stdio'
pulling subrepo config/BuildSystem from ssh://petsc@petsc.cs.iit.edu//home/petsc/BuildSystem-subrepo
adding changesets
adding manifests
adding file changes
added 4 changesets with 4 changes to 4 files (+1 heads)
resolving manifests
getting config/packages/BlasLapack.py
getting config/setCompilers.py
getting jeff
getting joe
getting urlMappingLocal.py
getting config/examples/asterix/asterix64.py
getting makefile
resolving manifests
resolving manifests
1 files updated, 0 files merged, 0 files removed, 0 files unresolved
abort: uncommitted changes in subrepo config/BuildSystem
(use --subrepos for recursive commit)
[balay at maverick petsc-buildsystem-dev]$ hg -q heads -R config/BuildSystem
2832:6ab6f1ae4aff
2828:358afb29fe48
23601:007d9928edc8
23599:a7b4f38e3075
