[petsc-dev] Fwd: [petsc-maint #119133] petsc-dev configure crash
Wed Jun 6 11:24:15 CDT 2012
Begin forwarded message:
> From: John Mousel <john.mousel at gmail.com>
> Date: June 6, 2012 10:12:19 AM CDT
> To: Jed Brown <jedbrown at mcs.anl.gov>
> Cc: petsc-maint at mcs.anl.gov, petsc-dev at mcs.anl.gov
> Subject: Re: [petsc-maint #119133] petsc-dev configure crash
> Reply-To: petsc-maint at mcs.anl.gov, John Mousel <john.mousel at gmail.com>
> Thanks Jed. Somehow I forgot to put the post-pull in .hg/hgrc for that
> build.
   With all the other unneeded bells and whistles in hg, why doesn't it have a mechanism where WE can put this post-pull business into the repository instead of telling each user to do that?
   Barry
> On Wed, Jun 6, 2012 at 10:03 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> You need to pull BuildSystem.
>> On Wed, Jun 6, 2012 at 10:00 AM, John Mousel <john.mousel at gmail.com>wrote:
>>> I'm getting the following after pulling and reconfiguring:
>>>            Configuring PETSc to compile on your
>>> system
>>> It appears you do not have valgrind installed on your
>>> system.
>>> We HIGHLY recommend you install it from www.valgrind.org
>>> Or install valgrind-devel or equivalent using your package
>>> manager.
>>> Then rerun
>>> ./configure
>>> TESTING: configureRegression from
>>> PETSc.utilities.Regression(config/PETSc/utilities/Regression.py:32)
>>> CONFIGURATION CRASH  (Please send configure.log to
>>> petsc-maint at mcs.anl.gov)
>>> John
