[petsc-dev] [petsc-maint #119133] petsc-dev configure crash
John Mousel john.mousel at gmail.com
Wed Jun 6 10:12:15 CDT 2012
Thanks Jed. Somehow I forgot to put the post-pull in .hg/hgrc for that
build.
On Wed, Jun 6, 2012 at 10:03 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> You need to pull BuildSystem.
> On Wed, Jun 6, 2012 at 10:00 AM, John Mousel <john.mousel at gmail.com>wrote:
>> I'm getting the following after pulling and reconfiguring:
>>             Configuring PETSc to compile on your
>> system
>> It appears you do not have valgrind installed on your
>> system.
>> We HIGHLY recommend you install it from www.valgrind.org
>> Or install valgrind-devel or equivalent using your package
>> manager.
>> Then rerun
>> ./configure
>> TESTING: configureRegression from
>> PETSc.utilities.Regression(config/PETSc/utilities/Regression.py:32)
>> CONFIGURATION CRASH  (Please send configure.log to
>> petsc-maint at mcs.anl.gov)
>> John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120606/63431b33/attachment.html>
