[petsc-dev] switch petsc-dev to use --with-shared-libraries by default?
Fri Jun 1 13:09:02 CDT 2012
On Fri, Jun 1, 2012 at 1:05 PM, Aron Ahmadia <aron.ahmadia at kaust.edu.sa>wrote:
> Broken on BG/P with XL compilers, but this is a BuildSystem issue.
I recall you were fighting with this recently. Did you figure out what was
wrong?
Does it really make sense for any normal user to build with shared libs
there?
I agree with Barry about the user experience building on most common
hardware: laptops, desktops, and small servers.
> A
> On Fri, Jun 1, 2012 at 9:03 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >    Is it time to change in petsc-dev the default of
> --with-shared-libraries to true by default? It is a nicer user experience
> to use shared libraries (much faster link of executable for example).
> >    Does it work pretty much everywhere?
> >   Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120601/7071e7a9/attachment.html>
