[petsc-dev] switch petsc-dev to use --with-shared-libraries by default?
Aron Ahmadia aron.ahmadia at kaust.edu.sa
Fri Jun 1 13:05:05 CDT 2012
Broken on BG/P with XL compilers, but this is a BuildSystem issue.
A
On Fri, Jun 1, 2012 at 9:03 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Is it time to change in petsc-dev the default of --with-shared-libraries to true by default? It is a nicer user experience to use shared libraries (much faster link of executable for example).
>    Does it work pretty much everywhere?
>   Barry
