[petsc-dev] Regression tests
Thu Jul 26 14:31:34 CDT 2012
On Thu, Jul 26, 2012 at 2:17 PM, Matthew Knepley <knepley at gmail.com> wrote:
> You can tell from the primary key what it is. If the primary key is wrong,
> it does not help you in your scenario as it could be
> misspelled, or intended to be put in another directory. This is dubious at
> best.
I don't need the primary key to be "right" to have good diagnostics, I just
need to know that the Test() declaration (which executes code at the time
the test is created) is inconsistent. My error message tells you the line
that is bad. This is important.
> We should have a discussion about whether we want to support this after
> 3.3.
What's the problem? Is builder.py having trouble figuring out how to link
PETSc in general? Maybe it should use "make getlinklibs". ;-D
Note that people occasionally ask for minimal builds for low-level
functionality. Barry was even asking if it would be feasible to have a way
to build only some KSPs, PCs, and matrix formats. I like that the option
keeps us honest.
No no. Your original make log is in PETSC_ARCH/conf/make.log. It should
> never be corrupted. You
> remove the link at make.log.bkp.
Well, that's an interesting (and confusing) idea for how it *could* work
some day, but it's not how it currently works.
> Same way we do in the makefiles now. It has an attribute "complex",
> "superlu", etc.
So what you're saying is that your system could be extended to do this? I'm
not disagreeing, but I think my suggestion is more maintainable and
extensible. As I said in my first reply, the differences are mostly
cosmetic, but I think there is good reason to prefer the form I suggest.
The important thing in either case is to have a database of tests so we can
program behavior.
> Some have these.
Held separately?
regressionRequirements = {'src/vec/vec/examples/tests/ex31':
 set(['Matlab'])
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120726/6b7b5324/attachment.html>
