[petsc-dev] Regression tests
Thu Jul 26 14:17:35 CDT 2012
On Thu, Jul 26, 2012 at 1:52 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Jul 26, 2012 at 1:30 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Thu, Jul 26, 2012 at 12:21 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> Builder does some of this, but I think not all, and I don't think it's
>>> as convenient. The differences are partly syntactic. First, to add a test,
>>> you have to add lines to a single global file (currently 1500 lines). By
>>> creating the dictionary globally, we can't do consistency checks when the
>>> test is declared, instead you only do it later once you have lost line
>>> number information. You also can't build in the source directory, or
>>> anything similar, which makes it hard for a user to split an example out
>>> into their own toy project. Since you mess around with stdout, we are
>>> losing warning messages (including color) and lose some Emacs M-x compile
>>> convenience. (this can be fixed easily enough).
>> 1) I am fine with changing where the options come from, meaning if we
>> want to also check for an import somewhere. Personally, I think
>>     its easier to maintain a central database than a distributed
>> database. I would only suggest a distributed database for scalability, which
>>     we do not need.
>> 2) I take your point about users adding tests (extensibility), which is
>> why I would be fine with checking for an import
>> 3) I have no idea what you mean about consistency checks
> Suppose the user misspells a file name or dict key, or they forget a
> mandatory key. With a dict, all you can do is spit out the entry that you
> think is corrupt and the user is on their own to figure out where the
> declaration is in the file. With my model, you immediately get the file and
> line number where the invalid record was created. With separate files, we
> can also get more context-sensitive behavior to avoid repeating ourselves
> so much.
You can tell from the primary key what it is. If the primary key is wrong,
it does not help you in your scenario as it could be
misspelled, or intended to be put in another directory. This is dubious at
best.
>> 4) You can run builder on source anywhere. This is how I check the crazy
>> things people send us.
>>> Note that my suggestion does not _prevent_ using a global script, but it
>>> localizes the declaration and would make it possible to run locally.
>>> On Thu, Jul 26, 2012 at 11:37 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> ./test.py build ex19
>>> $ config/builder2.py buildExample src/snes/examples/tutorials/ex19.c
>>> Namespace(files=['src/snes/examples/tutorials/ex19.c'], func=<function
>>> buildExample at 0x1fa56e0>)
>>> Building ['/home/jed/petsc/src/snes/examples/tutorials/ex19.c']
>>> ERROR IN LINK ******************************
>>>                      /usr/bin/ld: cannot find -lpetsc
>>>                                        collect2: error: ld returned 1 exit
>>> status
>>> (maybe it doesn't work --with-single-library=0)
>> It does not. I don't see a reason to support this. If its does, it is
>> accidental.
> It's still a supported option in PETSc. I use it in my default PETSC_ARCH
> because (a) link is one second faster and (b) it keeps us honest about
> dependencies.
We should have a discussion about whether we want to support this after 3.3.
>>> $ PETSC_ARCH=mpich-singlelib config/builder2.py buildExample
>>> buildExample at 0x25dd6e0>)
>>> (hmm, where is the executable anyway)
>>> $ ls -ltr | tail -3
>>> lrwxrwxrwx 1 jed users       35 Jul 26 11:57 make.log.bkp ->
>>> /home/jed/petsc/mpich/conf/make.log
>>> lrwxrwxrwx 1 jed users       45 Jul 26 11:58 make.log ->
>>> /home/jed/petsc/mpich-singlelib/conf/make.log
>>> -rw-r--r-- 1 jed users  5271714 Jul 26 11:58 RDict.log
>>> (oh cool, it overwrote my library build with the make.log from this
>>> example)
>> It shouldn't. It should move make.log to make.log.bkp first. There must
>> be a bug.
> So the second time I run it, the original make.log is gone. Not better.
No no. Your original make log is in PETSC_ARCH/conf/make.log. It should
never be corrupted. You
remove the link at make.log.bkp.
>>> $ cat make.log
>>>   Loaded configure to cache: size 298004
>>>   Compiling C files
>>>         Pushing language C
>>> /opt/mpich2/bin/mpicc -c -I/home/jed/petsc/mpich-singlelib/include
>>> -I/home/jed/petsc/include -I/home/jed/petsc/mpich-singlelib/include
>>> -I/home/jed/usr/elemental-mpich/include -I/usr/include
>>> -I/opt/mpich2/include  -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing
>>> -Wno-unknown-pragmas -g3 -fno-inline -O0     -MMD -D__INSDIR__=
>>> sh: /opt/mpich2/bin/mpicc -c -I/home/jed/petsc/mpich-singlelib/include
>>> Executing: /opt/mpich2/bin/mpicc -c
>>> -I/home/jed/petsc/mpich-singlelib/include -I/home/jed/petsc/include
>>> sh:
>>>         Popping language C
>>>         Moving ex19.o to
>>> /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.o
>>>         Moving ex19.d to
>>> /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.d
>>> Linking object ['/home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.o']
>>> into /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19
>>>     Pushing language C
>>>                                 Pushing language C
>>>                                 Popping language C
>>>                                 Pushing language CUDA
>>>                                 Popping language CUDA
>>>                                 Pushing language Cxx
>>>                                 Popping language Cxx
>>>                                 Pushing language FC
>>>                                 Popping language FC
>>>         Pushing language C
>>>         Popping language C
>>> sh: /opt/mpich2/bin/mpicc  -o
>>> /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19    -fPIC -Wall
>>> -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -g3 -fno-inline
>>> -O0 /home/jed/petsc/mpich-singlelib/lib/ex19-obj/ex19.o
>>> -L/home/jed/petsc/mpich-singlelib/lib -lpetsc
>>> -Wl,-rpath,/home/jed/petsc/mpich-singlelib/lib
>>> -L/home/jed/petsc/mpich-singlelib/lib -ltriangle -lX11 -lchaco -lparmetis
>>> -lmetis -Wl,-rpath,/home/jed/usr/elemental-mpich/lib
>>> -L/home/jed/usr/elemental-mpich/lib -lelemental -lplcg -lpmrrr -lamspub
>>> -lml -Wl,-rpath,/opt/mpich2/lib -L/opt/mpich2/lib
>>> -Wl,-rpath,/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1
>>> -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -lmpichcxx -lstdc++ -lpthread
>>> -lblacs -lHYPRE -lmpichcxx -lstdc++ -Wl,-rpath,/usr/lib -L/usr/lib
>>> -lcholmod -lamd -lcolamd -lcamd -lccolamd -lumfpack -lcholmod -lcamd
>>> -lccolamd -lcolamd -lamd -llapack -lblas -lm -L/usr/local/cuda/lib
>>> -L/usr/lib/gcc/x86_64-unknown-linux-gnu/4.7.1 -ldl
>>> -Wl,-rpath,/opt/mpich2/lib -lmpich -lopa -lmpl -lpthread -lrt -lgcc_s -ldl
>>> Executing: /opt/mpich2/bin/mpicc  -o
>>> sh:
>>>     Popping language C
>>> (the above output loses warnings)
>> Bug.
>>> $ mpich-singlelib/lib/ex19-obj/ex19 -happy-running
>>>>> ./test.py check ex19_fas
>>> $ PETSC_ARCH=mpich-singlelib config/builder2.py check --testnum 5
>>> Namespace(args=[], files=['src/snes/examples/tutorials/ex19.c'],
>>> func=<function check at 0xfe17d0>, retain=False, testnum=5)
>>> All tests pass
>>> (edit file, insert syntax error, re-run)
>>> [same output as above]
>>>>> ./test.py check ex19_\* # run all the ex19 tests
>>>>> ./test.py check -n 16 --if '(X || Fortran) && !Complex'
>>> How?
>> Internally it knows all these predicates like num processes, Fortran and
>> complex.
> It knows Fortran only in that the source file is Fortran. How does it know
> whether an example supports complex or whether a given run uses SuperLU,
> etc?
Same way we do in the makefiles now. It has an attribute "complex",
"superlu", etc.
> There is no command line syntax for it. I did
>> not think there was for make either.
> It's manual through TESTEXAMPLES_SUPERLU, etc.
>> You can do that from the run parameters at the op of builder.py.
> I don't think so. I think you have to add another dict key to your example
> declarations.
Some have these.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120726/5ff4a912/attachment.html>
