[petsc-dev] Regression tests
Thu Jul 26 11:11:26 CDT 2012
On Thu, Jul 26, 2012 at 11:08 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 26 Jul 2012, Jed Brown wrote:
> > On Thu, Jul 26, 2012 at 10:41 AM, Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > The naming/clasification is not perfect.
> > > Looks like Barry tried to fix this - by adding a target
> > > tests_DATAFILESPATH - but now it has both C and fortran examples in
> > > it? [i.e TESTEXAMPLES_FORTRAN_NOCOMPLEX and TESTEXAMPLES_C_NOCOMPLEX]
> > > http://petsc.cs.iit.edu/petsc/petsc-dev/rev/c37110e4b450
> > > Perhaps this stuff needs an overhaul..
> > I also think it should be overhauled so that examples can be tagged when
> > they are declared. I think that Python declarative syntax is easy, but it
> > would be good to parse the existing makefiles to avoid needing a manual
> > conversion.
> > Is everyone okay with the test suite depending on Python?
> I think python is fine - as long as the run targets still remain in
> the makefile.
I am fine with having run targets, AS LONG as they are not shell. Make them
Python.
Make can run python just as well as shell/
    Matt
> Are you saying each 'run' target in the makefile will be tagged - and
> the python script will parse this tag?
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120726/984c2b41/attachment.html>
