[petsc-dev] Jack has produced a scalable sparse direct solver
Jack Poulson jack.poulson at gmail.com
Mon Jul 23 12:12:08 CDT 2012
Hi Hong,
On Mon, Jul 23, 2012 at 11:53 AM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
> Jack:
>> I'm getting started on creating documentation right now; it should end up
>> looking very similar to Elemental's.
> The detailed instruction will be very helpful, especially
> the sparse matrix data structures. Notify us when the documentation is out.
Will do. I just pushed out documentation for the build system:
http://poulson.github.com/Clique/build.html
The rest should follow soon.
> Is this a sparse Cholesky direct solver?
More or less. It currently supports LDL^T and LDL^H factorizations without
pivoting, and the latter certainly works for Hermitian positive-definite
matrices. The current implementation is slightly more general than Cholesky
and should achieve roughly the same performance.
> Currently, only mumps supports parallel sparse Cholesky direct solver.
> Yours will be a good addition to the petsc external solvers.
Thanks! I'll do my best to help with the integration when the time comes.
>> Please keep in mind that there is not _yet_ any support for pivoting, as
>> I needed Clique's functionality for indefinite complex symmetric matrices
>> which are nice enough to be factored accurately without pivoting.
> Petsc users likely use it as a preconditioner.
> In case of zero pivot, you may provide a routine/option for adding a small
> shift?
Yes, that is what I was thinking. For instance, for Helmholtz equations,
one can get away with very small positive imaginary shifts (the physically
corresponds to slightly damping waves).
>> Clique's nested dissection is built on top of a nodal graph bisection
>> routine which uses a custom interface to parmetis; I suspect that the graph
>> partitioning is currently the least scalable part of the black-box
>> interface due to KLFM refinement being so hard to parallelize.
> Xuan has almost finished the petsc-elemental interface
> (see petsc-dev/src/mat/impls/elemental/).
> We would appreciate if you can take a look at it and give us
> your comments/suggests.
I just took a quick look and will make time to go over it in detail later
today. I'll send out patch if I have any concrete suggestions.
Jack
>> On Mon, Jul 23, 2012 at 10:12 AM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>>> Xuan will take a look at this.
>>> Hong
>>> On Mon, Jul 23, 2012 at 9:47 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> I think we just need a small converter from AIJ:
>>>> https://bitbucket.org/poulson/clique/src/dc417c7e9403/tests/DistSparseMatrix.cpp
>>>>   Matt
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120723/e2a4f861/attachment.html>
