[petsc-dev] Jack has produced a scalable sparse direct solver
Hong Zhang hzhang at mcs.anl.gov
Mon Jul 23 11:53:30 CDT 2012
Jack:
> I'm getting started on creating documentation right now; it should end up
> looking very similar to Elemental's.
The detailed instruction will be very helpful, especially
the sparse matrix data structures. Notify us when the documentation is out.
Is this a sparse Cholesky direct solver?
Currently, only mumps supports parallel sparse Cholesky direct solver.
Yours will be a good addition to the petsc external solvers.
> Please keep in mind that there is not _yet_ any support for pivoting, as I
> needed Clique's functionality for indefinite complex symmetric matrices
> which are nice enough to be factored accurately without pivoting.
Petsc users likely use it as a preconditioner.
In case of zero pivot, you may provide a routine/option for adding a small
shift?
> Clique's nested dissection is built on top of a nodal graph bisection
> routine which uses a custom interface to parmetis; I suspect that the graph
> partitioning is currently the least scalable part of the black-box
> interface due to KLFM refinement being so hard to parallelize.
Xuan has almost finished the petsc-elemental interface
(see petsc-dev/src/mat/impls/elemental/).
We would appreciate if you can take a look at it and give us
your comments/suggests.
Hong
> On Mon, Jul 23, 2012 at 10:12 AM, Hong Zhang <hzhang at mcs.anl.gov> wrote:
>> Xuan will take a look at this.
>> Hong
>> On Mon, Jul 23, 2012 at 9:47 AM, Matthew Knepley <knepley at gmail.com>wrote:
>>> I think we just need a small converter from AIJ:
>>> https://bitbucket.org/poulson/clique/src/dc417c7e9403/tests/DistSparseMatrix.cpp
>>>   Matt
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20120723/9d710512/attachment.html>
